andynick69 0 Posted December 30, 2012 Report Share Posted December 30, 2012 hi guys,been using vr a few days for work,no problems,came out of work,wouldnt start? plenty of power in battery etc,any ideas? im thinking fuel pump? cheers Link to post Share on other sites
andynick69 0 Posted January 24, 2013 Author Report Share Posted January 24, 2013 bump,same problem again,any ideas please?? Link to post Share on other sites
craggsy 91 Posted January 24, 2013 Report Share Posted January 24, 2013 Do you hear it prime? Link to post Share on other sites
andynick69 0 Posted January 24, 2013 Author Report Share Posted January 24, 2013 i dont think so no,thats what makes me think a fuelling prob,no petrol smell at all regardless of pumping throtlle,what you thinking? Link to post Share on other sites
craggsy 91 Posted January 24, 2013 Report Share Posted January 24, 2013 Fuel pump relay Link to post Share on other sites
andynick69 0 Posted January 24, 2013 Author Report Share Posted January 24, 2013 Where's that ? Cost? Link to post Share on other sites
michael5556 247 Posted January 25, 2013 Report Share Posted January 25, 2013 Obd1 or 2? If it is the relay I may have a spare? Link to post Share on other sites
andynick69 0 Posted January 25, 2013 Author Report Share Posted January 25, 2013 Obd2,I've been told 15 quid? Link to post Share on other sites
michael5556 247 Posted January 25, 2013 Report Share Posted January 25, 2013 Obd2 doesn't prime until being cranked over. Check it's getting power when someone tries to turn it over. Link to post Share on other sites
legvw 0 Posted January 25, 2013 Report Share Posted January 25, 2013 Immob fault. Are you getting a spark? Link to post Share on other sites
andynick69 0 Posted January 25, 2013 Author Report Share Posted January 25, 2013 How do I check that, sorry Link to post Share on other sites
andynick69 0 Posted January 26, 2013 Author Report Share Posted January 26, 2013 can anyone tell me which relay is for the fuel pump?, theres about 6 under there,all have a number stamped on them?? nothing in owners manual but fuse plan Link to post Share on other sites
Lukey. 381 Posted January 26, 2013 Report Share Posted January 26, 2013 Fuel pump is 67, 80 or 167. Any of these can be fuel pump so just find the one that matches. Link to post Share on other sites
andynick69 0 Posted January 26, 2013 Author Report Share Posted January 26, 2013 cheers m8 Link to post Share on other sites
andynick69 0 Posted January 26, 2013 Author Report Share Posted January 26, 2013 relay changed and no joy,still continues to turn but not firing,think i need to get it on vagcom otherwise im gona keep guessing,anyone any other ideas? cheers andy Link to post Share on other sites
Lukey. 381 Posted January 26, 2013 Report Share Posted January 26, 2013 take the plugs out and touch them on the inlet while trying to start to see for sparks, best to take the fuel pump relay back out when doing this. Link to post Share on other sites
andynick69 0 Posted January 27, 2013 Author Report Share Posted January 27, 2013 Will try this when I'm home,somebody else has mentioned crank sensor? Link to post Share on other sites
SkippyVR6 1 Posted January 27, 2013 Report Share Posted January 27, 2013 sorry to jump in but i see you mentioned obd2 only primes when cranking, when i turn my ignition on i can hear a pump in the tank running is that not the primer pump?? mines a 98 Link to post Share on other sites
Gazbarber1982 3 Posted January 28, 2013 Report Share Posted January 28, 2013 Give the fuel lines a bit of a pinch under the bonnet. If the feed line is solid, it's getting fuel but if it's a bit soft, it's not. I did this after being told that a non running car my mate bought had already had it changed. Cost: £3 off ebay for second hand relay. Car now runs. Link to post Share on other sites
