roosevelt1st 1 Posted January 8, 2013 Report Share Posted January 8, 2013 Car has bin standing over Xmas period. now restarted and it runs very lumpy as if only running og 4/5 out of 6 cylinders, with relevenat loss of power....!Car is 1998 OBDII VR6just done a handheld code read, results as below; 00522 - Engine Coolant Temperature Sensor-G62 00533 - Idle Air Control Regulation 00553 - Mass Air Flow Sensor-G70two questions really, 1) what do the G62/G70 codes relate too? 2) do i need replacement MAF?comment pls + thanx Link to post Share on other sites
michael5556 247 Posted January 8, 2013 Report Share Posted January 8, 2013 I would start by replacing the temp sensor. The blue one in your thermostat housing. About £30 from Tps. And see if that solves the problem. Link to post Share on other sites
Lukey. 381 Posted January 8, 2013 Report Share Posted January 8, 2013 That could be causing all three problems IIRC.edit, if nothings changed and the car has just been standing, try simply plugging it on and off a few times and it might just miraculously work again. Link to post Share on other sites
Guy 1 Posted January 9, 2013 Report Share Posted January 9, 2013 I'd look at rosstech wiki, and see what those code relate to exactly. Link to post Share on other sites
Pieman 0 Posted January 9, 2013 Report Share Posted January 9, 2013 I would say it was the temp sensor. Link to post Share on other sites
roosevelt1st 1 Posted January 12, 2013 Author Report Share Posted January 12, 2013 Codes clearedWater Temp Sensor replaced today (£17+vat from VW) + Antifreeze!MAF cleaned (Halfords Contact Cleaner £4)Codes read - only one 00533 - Idle Air Control RegulationRoad test, seems better but still'missing' a bit.So advice pls how to rectify 00533 code, thanks Link to post Share on other sites
roosevelt1st 1 Posted January 26, 2013 Author Report Share Posted January 26, 2013 HT leads replaced, no difference.Coil pack replaced - voila problem fixed..... Link to post Share on other sites
