twolf1 0 Posted January 10, 2013 Report Share Posted January 10, 2013 Hi - There is a damp smell in car and has been for a while and noticed a slight damp patch on rear passenger foot-well.Thought the heater matrix split (as this happened in my last car) - but have no water leak in car and have never had to top the water up - this has been the case for a few months - Can it be anything else? its driving me bonkers ? Link to post Share on other sites
Lukey. 381 Posted January 10, 2013 Report Share Posted January 10, 2013 Lift the rear carpet and examine the floor bungs, there is one each side in the rear footwells, they may be letting water in. Link to post Share on other sites
twolf1 0 Posted January 11, 2013 Author Report Share Posted January 11, 2013 it has rained quite a bit recently so hopefully this is the problem.Where does the carpet lift without having to cut it?It it an easy job? and easy to fix if this is the prob? Link to post Share on other sites
Lukey. 381 Posted January 11, 2013 Report Share Posted January 11, 2013 The carpet lifts from under the seats, it's easiest to just take the seats out, which is just a spring clip removed at the front end and the little plastic trims taken off the runners at the back then the seats will just slide off the rails and can be easily removed. If this is the issue when you look but the bungs are still relatively ok then what I did was take them off, tidy them up and filled the middle of them with copious amounts of tiger seal. Reinstall then smooth the sealant/added more as necessary to make a good seal on both the inside and under the car, I would put some underseal on the underneath area again to seal all the repair in from the elements. If its totally had it and rusted out the hole and isnt salvageable you would then be bet to cut out the rot and weld in a patch. This obviously all depends on what you find. Best of luck Link to post Share on other sites
Lukey. 381 Posted January 11, 2013 Report Share Posted January 11, 2013 Also if you do investigate with the seats out there are some more bungs under the seats and in the front footwells, I would give them all a going over as they are a common place to do just these things. Link to post Share on other sites
twolf1 0 Posted January 11, 2013 Author Report Share Posted January 11, 2013 thanks for response - appreciated Link to post Share on other sites
