hi just a quick post ive started my mk 2 conversion engines out and dash is out im puttin a vr6 into it obd2 my golf is a g reg so i think its got the 90 spec fuse box so do i just unplug the engine loom out my mk 2 and do the same with the vr6 plz has any 1 done this conversion already thanks
I'm assuming your using a hydraulic clutch? And not converting it too cable.
It's something too do with the push rod too the clutch m/c and the golf pedal boxes don't push it in far enough. Corrados were just a different shape mk2 hence why everything can be swapped over.
