golfmad 0 Posted March 3, 2013 Report Share Posted March 3, 2013 hi just a quick post ive started my mk 2 conversion engines out and dash is out im puttin a vr6 into it obd2 my golf is a g reg so i think its got the 90 spec fuse box so do i just unplug the engine loom out my mk 2 and do the same with the vr6 plz has any 1 done this conversion already thanks Link to post Share on other sites
michael5556 247 Posted March 4, 2013 Report Share Posted March 4, 2013 Yeah, that's pretty much it. As long as it's 90 spec fusebox. What clocks are you running? Link to post Share on other sites
golfmad 0 Posted March 4, 2013 Author Report Share Posted March 4, 2013 my vr6 clocks mate Link to post Share on other sites
golfmad 0 Posted March 4, 2013 Author Report Share Posted March 4, 2013 how do i no its 90 spec ive been told as long as my hazzard light is on my stalk its 90 spec mine is on the stalk Link to post Share on other sites
VR6Pete 1,455 Posted March 4, 2013 Report Share Posted March 4, 2013 I changed my steering column in my mk2 conversion and had the mk3 stalks with the hazard light on the top of the steering wheel cowl Link to post Share on other sites
golfmad 0 Posted March 4, 2013 Author Report Share Posted March 4, 2013 i already have the hazzard light on top already Link to post Share on other sites
michael5556 247 Posted March 4, 2013 Report Share Posted March 4, 2013 Then it will/should be 90spec. The plugs won't fit into a ce1 fusebox anyway as they are a different shape. Link to post Share on other sites
golfmad 0 Posted March 5, 2013 Author Report Share Posted March 5, 2013 ok thanks for ur help can some 1 answer me the question as for y i cant use the vr6 pedel box y passat or corrado Link to post Share on other sites
michael5556 247 Posted March 5, 2013 Report Share Posted March 5, 2013 I'm assuming your using a hydraulic clutch? And not converting it too cable.It's something too do with the push rod too the clutch m/c and the golf pedal boxes don't push it in far enough. Corrados were just a different shape mk2 hence why everything can be swapped over. Link to post Share on other sites
golfmad 0 Posted March 5, 2013 Author Report Share Posted March 5, 2013 thanks for your help guys Link to post Share on other sites
