964russ 0 Posted March 24, 2013 Report Share Posted March 24, 2013 Recently got a vr6 highline, it had a cheap cone filter.The breather pipe was left hanging!So ive found the correct k&n, this has a pipe to connect the breather but allso has a vw sensor fitted to it.This sensor, wots it for? Temp?Does it connect to the plug on the top of the breather, the cold start valve thingy.Ill take a pic in the morning.Thanks. Link to post Share on other sites
VR6Pete 1,455 Posted March 24, 2013 Report Share Posted March 24, 2013 Recently got a vr6 highline' date=' it had a cheap cone filter.The breather pipe was left hanging!So ive found the correct k&n, this has a pipe to connect the breather but allso has a vw sensor fitted to it.This sensor, wots it for? Temp?Does it connect to the plug on the top of the breather, the cold start valve thingy.Ill take a pic in the morning.Thanks.[/quote']Pretty sure that is a dummy plug mate that appears to plug in the breather Link to post Share on other sites
VIW28 29 Posted March 24, 2013 Report Share Posted March 24, 2013 It had no bearing on your ecu's behaviour so don't worry about it, it won't affect how the car runs Link to post Share on other sites
964russ 0 Posted March 26, 2013 Author Report Share Posted March 26, 2013 Left plug hanging, plumbed breather in and made up a heat shield.Along wiv stainless pipe sounds great. Link to post Share on other sites
VR6Pete 1,455 Posted March 27, 2013 Report Share Posted March 27, 2013 good work that man Link to post Share on other sites
ssaunders 199 Posted March 29, 2013 Report Share Posted March 29, 2013 Hi, do you mean the infamous PCV valve? Top left corner of crankcase into concertina (PCV) then into plastic intake before throttle? If so then Pete is right, looks like a sensor but isn't, I haven't blanked mine and don't know the pro's and cons are but some people use a catch can, it basically passes excess gas from crankcase back into intake to reduce emissions.RegardsSteve Link to post Share on other sites
