mk3luke 5 Posted March 24, 2013 Report Share Posted March 24, 2013 Hi guys, my golf had the classic unplugged abs air bag light combo. so i has a quick look found the wire and plugged it back in.would you believe it the airbag and abs lights came on! scanned it with vcds lite on my laptop and got lhf wheel speed sensor and drivers airbag ignitor resistance high.put in a new wheel speed sensor and the light went out and cleared the codes, now i have abs! hoorah.(yet to sort the airbag, got a coil spring coming in the post)But now my problem is this, when i start the car the abs light does not come on then go out! (but there are no fault codes and the abs defo works!)any ideas?cheersluke Link to post Share on other sites
VR6Pete 1,455 Posted March 24, 2013 Report Share Posted March 24, 2013 has your bulb gone? Stick a multi-meter on the terminals of the bulb and see if get a "spike" in the voltage Link to post Share on other sites
mk3luke 5 Posted March 26, 2013 Author Report Share Posted March 26, 2013 sorted, it was the bulb! doh! but now i have a problem, i have two dash clusters, one the abs light works airbag doesnt, and the other one works opposite!so now i have to un-solder one bulb and re solder it to the other ! looks like a pain in the ass!!i take it there is no other way?!? i dont want to buy yet another cluster!cheersluke Link to post Share on other sites
Lukey. 381 Posted March 26, 2013 Report Share Posted March 26, 2013 I unsoldered and re soldered mine as they both blew, to make it easier (& likely to never blow again) I used LEDs instead of incandescent and used small lengths of wire in between, tacking the LEDs in the holes of the holder with a dot of hot glue. Link to post Share on other sites
