Crank Position Sensor Part #
Anyway if its CRANK I found 021 906 433 A, that is the newest part number under Corrado.
There is 021 906 433 C under Golf and usually a higher letter just means a revision of the same part.
If you google that it also says that 021 906 433 C is the same aswell, so up to you which you look for
