cpfcvr6 6 Posted March 27, 2013 Report Share Posted March 27, 2013 hi, changed the plugs today and they are black which indicates its runnign rich, ive also noticed a 15-20 miles less on a fill up of fuel, any ideas why? going to clean the maf but any other tips? golf vr6 obd1. Link to post Share on other sites
VR6Pete 1,455 Posted March 27, 2013 Report Share Posted March 27, 2013 I know if the blue thermo temp sensor is faulty it could cause it to over fuel, and also if you have a low temp thermostat, it will take longer to warm up, so will throw more fuel in. Link to post Share on other sites
Daverse 175 Posted March 27, 2013 Report Share Posted March 27, 2013 I'd stick it on vagcom, that will point you in the ri direction. Is it running ok? most likely a sensor, MAF, lambda or a temp one. Hope that helps. Link to post Share on other sites
cpfcvr6 6 Posted March 27, 2013 Author Report Share Posted March 27, 2013 I'd stick it on vagcom' date=' that will point you in the ri direction. Is it running ok? most likely a sensor, MAF, lambda or a temp one. Hope that helps.[/quote']cleaned the maf, the blue temp sensor is brand new and the lambda is about a year old. regardsseems to be running fine. Link to post Share on other sites
ssaunders 199 Posted March 28, 2013 Report Share Posted March 28, 2013 Hi, mine was running rich, stank of petrol and took ages to settle to idle, vag com said no issue turned out it was dodgy thermostat, changed blue sensor and nearly everything else. Give it a look.Good luck.Steve Link to post Share on other sites
