front fog light removal?
Unclip centre refector, undo the two cross-head screws then pull the right-side towards you which should in-turn release the clip on the left side of the fog.
Wear mechanics gloves to release the connector at the back of the foglamp to avoid ripping the back of your hand, the cable is a quite short.
When refitting make sure you put the right-side in position then press the left side to clip the foglamp back into place.
