A few fluid related questions
* how many litres of brake fluid do i need to fill and bleed the brake/clutch system again, any recommendatons on product?
* Same as above but with powersteering fluid, is there a particular type i need and roughly how many litres?
* Is there a correct way of fitting new fuel pipe in the bay as there is a blue and a black pipe from the bay that leads underneath, does it matter which way around the pipes from the fuel rail fit these?
Thanks in advance
1 bottle of green PAS fluid from VW is enough, they only sell one kind so just ask for it. It needs to be the VW green stuff as above for that reason.
If you are wanting to flush the steering rack get 2 bottles and put a whole bottle through the system.
Don't take this as gospel but I think the black is feed and blue is return.
