Video How-to: Replace VR6 EVAP Canister Purge Regulator Valve (N80)
Here you go mate, this is how it should look:
I'd say your PCV valve has been removed, also check on the manifold see if its blocked off, if it isn't, then your car might not be running as it should, the pipe goes over the PCV as seen in the photo, and goes into the manifold behind spark plug number 3.
