Lukey. 381 Posted May 5, 2013 Report Share Posted May 5, 2013 I've just finished doing new chains, guides etc, headgasket and clutch. I'm now getting quite bad shudder, I thought it was just when engaging the clutch and setting off so thought it's the brand new clutch. The shudder only happens on pulling away or holding on the clutch, once going and through subsequent changes its fine. But I have just noticed now that the engine shudders more in neutral too when giving slight revs, like 1000, the shake goes away after and is fine at higher revs.It didn't shudder before whatsoever so must be something that's happened in this job.I tightened the flywheel according to the torque specs and stages and tightened in opposite sequence. The clutch was centred and I could slide the alignment tool in and out no problem and the box slid straight on too. The pressure plate was off on one dowel slightly but I managed to tap it on and then tightened the pressure plate bolts again according to the torque specs and stages and tightened in opposite sequence so centred itself out and evenly.Its only got about 30 miles on it at the mo and I've googled new clutch shudder and things say give it 1000 miles, but I've not just put on a new clutch I've removed and re installed the flywheel too but I'm in 2 minds whether its the flywheel now or what and should I get a new flywheel to have all new? They are an exchange item from VW so people must replace them a fair bit, and you can get a new sachs flywheel from ebay for about 50 quid. Link to post Share on other sites
Woodyman84 3 Posted May 5, 2013 Report Share Posted May 5, 2013 Sounds silly but have u vag com it just to rule out that it's not something completely unrelated? Link to post Share on other sites
Lukey. 381 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Yea I have and there's no fault codes, I've also taken the leads off one at a time just to be sure in case one cylinder wasn't firing causing the imbalance. Link to post Share on other sites
Daverse 175 Posted May 5, 2013 Report Share Posted May 5, 2013 it could be something loose, like a mount or something? Link to post Share on other sites
Lukey. 381 Posted May 7, 2013 Author Report Share Posted May 7, 2013 Ive checked the mounts and did double check the bolts on the clutch and flywheel when reinstalled. It feels like an imbalance. Link to post Share on other sites
Lukey. 381 Posted May 7, 2013 Author Report Share Posted May 7, 2013 Well I'll soon find out, I've just set fire to my wallet again and bought a genuine one. Link to post Share on other sites
Lukey. 381 Posted May 8, 2013 Author Report Share Posted May 8, 2013 Just my luck its on back order 5-7 days. Just hope this is the issue, and also that driving it 40 or 50 miles hasn't damage anything, I'm imagining the wobble could have damaged the crank or bearings, feeling paranoid! I'm not driving it until its sorted now. Link to post Share on other sites
ssaunders 199 Posted May 9, 2013 Report Share Posted May 9, 2013 Hi, i am interested on how you get on, i have a very slight 'wobble' on pull away after clutch,chains and lightened flywheel, very low rpm goes by 900. i only really notice it when balancing on the clutch. its been 2 months and about 700 miles and no problems.good lucksteve Link to post Share on other sites
Lukey. 381 Posted May 9, 2013 Author Report Share Posted May 9, 2013 I actually noticed that the vibration doesn't go at higher revs, the vibration just gets kind of so fast that you didn't notice it as much, that's why I've stopped driving it, like just over 1.3krpm was like the resonant frequency so it was worst at that point. Link to post Share on other sites
ssaunders 199 Posted May 9, 2013 Report Share Posted May 9, 2013 ok, i will have to check mine, i put it down to the light flywheel and not having the crank balanced. what does yours feel like its doing at 1.3k, so i know what to look/feel for? once my clutch is engaged i dont think i feel anything.s Link to post Share on other sites
Lukey. 381 Posted May 9, 2013 Author Report Share Posted May 9, 2013 At 1.3 when still and clutch down so the clutch disc isn't even contacting, the whole car shakes enough that you can feel it, then after it gets much less but you can still feel it isn't right and shaking. If engaging the clutch the shuddering is way bad, the whole car shakes. Then if going along a smooth road I can hear the vibration rattling something in the dash. The faster rpms the faster the rattle.I tested this down a long hill too, if going down the hill in gear, say 3rd at 30mph the rattling can be heard, if I then turn the engine off it will silently coast down the hill, turn back on and in gear again and the rattle comes back.At idle speeds the rattle is minimal, but it still feels more imbalanced than it did before I took the flywheel off. Link to post Share on other sites
ssaunders 199 Posted May 9, 2013 Report Share Posted May 9, 2013 Oh dear, nothing like mine. defo sounds like a balance issue, good luck. sorry i'm no help.S Link to post Share on other sites
Lukey. 381 Posted May 11, 2013 Author Report Share Posted May 11, 2013 Got the new flywheel on, the pressure plate would only go on one way on this new one, on the old one the dowels would move so it would go on in all 3 positions, so fingers crossed this will solve it, makes sense that if its only supposed to go on one way it may be weighted. I'll find out tomorrow I spose. Link to post Share on other sites
VR6Pete 1,455 Posted May 11, 2013 Report Share Posted May 11, 2013 Good Luck mate! Link to post Share on other sites
Lukey. 381 Posted May 11, 2013 Author Report Share Posted May 11, 2013 Giving up for today, I hired a hoist for the weekend to make getting the gearbox on/off easier as the fronts on this time, it helped a lot don't think I could have done it without it, but i smashed my head on it and have a bad head now lol +o( Link to post Share on other sites
Woodyman84 3 Posted May 11, 2013 Report Share Posted May 11, 2013 Ouch hope ur ok mate, that does sound like what could be the issue.mate. If it's weighted an on wrong then at certain revs it would cause.some vibrations. Really hope it sorts it, Got my fingers crossed for.you Link to post Share on other sites
Lukey. 381 Posted May 11, 2013 Author Report Share Posted May 11, 2013 With this revelation I could have just turned the pressure plate round but the flywheel was special order anyway so you don't get a refund so put it on anyway haha Link to post Share on other sites
Lukey. 381 Posted May 12, 2013 Author Report Share Posted May 12, 2013 Got the gearbox on, twice, the lever arm didn't go into place right and wouldn't travel forward first time so had to crack it off again, which wasted about an hour so haven't driven it yet, but I did start it up and raise the revs with the axles still disconnected and the signs look / feel good. Link to post Share on other sites
Woodyman84 3 Posted May 12, 2013 Report Share Posted May 12, 2013 Fingers and.toes crossed for you mate. Bet u was cursing that gearbox by the end! Link to post Share on other sites
Lukey. 381 Posted May 12, 2013 Author Report Share Posted May 12, 2013 The man walking his dog across the road certainly gave me a funny look when I was shouting and chucking stuff lol Link to post Share on other sites
Daverse 175 Posted May 12, 2013 Report Share Posted May 12, 2013 Haha, they are tricky little buggers! Hopefully its all sorted now for you matey. Link to post Share on other sites
Lukey. 381 Posted May 13, 2013 Author Report Share Posted May 13, 2013 Got the splash shield on and went for a test drive and I'm relieved to say its perfect now I had a close look at the old flywheel and got a straight edge on it, its no longer flat at all its dished, I looked at the new Valeo friction disc and it only contacted about 2cms of the edge with the original flywheel, so I'm pretty glad I did get a new flywheel on aswell. Link to post Share on other sites
