I removed spark plug number 6 from my car the other day, and it's covered in oil.
I noticed some splashes of oil on the inside of the metal HT lead cover.
The top half of the ceramic end of the plug was clean, the hexagonal 'nut' is totally black and oily and the thread is oily as well. The electrode is slightly black and appears to have a moderate amount of carbonated oil residue on it.
So I have two quick questions. Firstly, is the oil likely to have come from inside the engine (as opposed to an external leak which has pooled into the number 6 spark plug hole)? Secondly, what are the most likely culprits (internal and external)?
I can't see anything obviously leaking components, so I'll probably end up taking the head off at some point in a bid to get to the root cause. But if anyone has some info before I get involved with that, it would be much appreciated.
