shrick manifold for obd1 vr6
You shouldn't need any adaptors, either the guide is wrong, or you don't have everything in the kit you've got.
What exactly do you have mate? upload a photo of what bits you have.
I have also moved this to the correct forum section.
You shouldn't need any adaptors' date=' either the guide is wrong, or you don't have everything in the kit you've got.
adaptors for the vacuum hoses etc??? this is the guide i found
http://www.corrado-club.ca/mods/schrick.html
Nah...
Taken from our fitting guide in the club members guides:
Step 16. The final part of the vacuum circuit is connecting a 4mm vacuum hose from port C on the vacuum tank to an appropriate Vauum feed from the engine.
Locate the brake servo hose. The brake servo hose is the hard rubber hose that goes from the front right of the manifold, round the back of the engine and into the brake servo (RHD assumed). There are two take-off points on this hose, just rear of the coil pack (or distributor) location. The take-off points are covered with green plastic plugs. Remove the green plug from one of the take-off points, and run a vacuum hose from this take-off point to port C on the vacuum tank.
You should support your club and you will get access to all these guides, and discount codes etc.. ;)
