vr6max 0 Posted March 18, 2004 Report Share Posted March 18, 2004 I'm the proud owner of a 92 vr6 which i got for a bargain due to the milege! Its done 140K and i've been told that after 100K this needs changing. There is no noise from the tensioners so should i just wait for the noise to come? ?! Link to post Share on other sites
ingham 5 Posted March 18, 2004 Report Share Posted March 18, 2004 if it ant broke dont fix it Link to post Share on other sites
nickbee 1 Posted March 18, 2004 Report Share Posted March 18, 2004 LOLDon't wait 'til the timing chain breaks or you'll be fixing a lot more than that!!! Link to post Share on other sites
ingham 5 Posted March 18, 2004 Report Share Posted March 18, 2004 timing chain : to replace £ 1000second hand engine £ 700chians dont break that easy! unless you know differant? Link to post Share on other sites
nickbee 1 Posted March 18, 2004 Report Share Posted March 18, 2004 They can break, but it's not happened to me! £1000? Seriously? I know people that have changed their own, although I couldn't. Link to post Share on other sites
jcorallo 0 Posted March 18, 2004 Report Share Posted March 18, 2004 HiAlthough the timing chains can stretch very slightly (knocks the cam timing off a little) the actual chains are normally reliable and last until the sun explodes.The tensioner blade on the other hand, is known to wear down by 100k miles, sometimes less, and you dont always get a rattle to indicate its wearing.If you are proficient with a spanner, within a few hours you can inspect the blade - you just have to remove the inlet manifold and cam cover.Unfortunately, as you prob know, its a gearbox off task to replace the blade if its badly worn...Cheers,Jules Link to post Share on other sites
ingham 5 Posted March 18, 2004 Report Share Posted March 18, 2004 thanks i did not know that, might check mine this winter Link to post Share on other sites
VR6Andy 0 Posted March 18, 2004 Report Share Posted March 18, 2004 Ref the chain, i've heard similar that the sun will fall from the sky before it breaks. Link to post Share on other sites
warwickA2VR 0 Posted March 18, 2004 Report Share Posted March 18, 2004 my cylinder head is coming off soon to do the gasket so I can inspect the chain now. what does a worn tensioner blade look like? is it difficult to get the gearbox off to fit a new tensioner or is that a step to far for a learner vr6 mechanic?[ Edited Thu Mar 18 2004, 06:03PM ] Link to post Share on other sites
acf8181 0 Posted March 18, 2004 Report Share Posted March 18, 2004 do you mean the back runner thingy...mines worn...but i ain't takin off the gearbox to change it..may be able to without tho, am lookin into it now!i'm leaving the chains till i get a new 'box and doin both at the same time. Link to post Share on other sites
VR6Steve 0 Posted March 18, 2004 Report Share Posted March 18, 2004 The box is an absolute pig to get out and requires persuasion. As for the tensioner basically wears thin or ends up with a big grooved wear line through the middle. Link to post Share on other sites
acf8181 0 Posted March 19, 2004 Report Share Posted March 19, 2004 The box is an absolute pig to get out and requires persuasion. As for the tensioner basically wears thin or ends up with a big grooved wear line through the middle.not really gonna do much is it? Link to post Share on other sites
VR6Steve 0 Posted March 19, 2004 Report Share Posted March 19, 2004 My mate did a set on a Corrado (he's done about 3 sets now) and there was almost nothing left of the top one. If it gave way, i don't think I would have wanted to see the results. Link to post Share on other sites
FishWick 21 Posted March 22, 2004 Report Share Posted March 22, 2004 Any tried the solid polymer upper blade with sring loaded/hyrdaulic tensioner bolt as replacements?I know they're from the very late 12V VRs the Americans got in their MK4s, but the basic dimensions seem to be the same.I bought a new upper blade the other day, and to be honest, looking at it....I don't want to put it in. Doesn't look like it'll last 5 minutes....but it will, just looks like it won't!. I notice VW have changed the bakelite coloured plethyronic (sp?) coating with some new grey stuff....not sure if it's any better tho.K[ Edited Mon Mar 22 2004, 12:46PM ] Link to post Share on other sites
