Fan controller help needed!
Hi guys, I'm in need of a bit advice from you lecky experts out there.
I'm looking for a fan controller (revotec fan controller) to power the slim fans I have bought for my turbo project. I know people in the past have wired them into the existing fan controller to retain the 2 or 3 speed setup which is fine but I want to run a simple temp adjustable single speed setup for maximum cooling and reliability. I'm really struggling for space in the engine bay too and ditching the OEM fan controller would be ideal.
Does anyone know if the original controller can be deleted or not and if so, is it a case of just removing the whole fan wiring harness? Just so you know, I'm hopeless when it comes to electrics so a simple solution would be ideal! :)
Thanks Pete, I wasn't aware of that. To be honest, I may ditch that too as it will give me even more clearance around the back of the coilpack. If I run with a basic one speed controller for the fans I might power them from a constant live rather than switched so that they continue to run until the rad reaches the cutoff temp. Decision decisions...
