drivers side low beam light staying on!! golf vr6 mark three.
Check you havent left your indicator stalk on when parked... When engine is turned off and indictor stalk is pushed into position it will bring on the "parking light" so if its in position to signal right then your side lights would be on. Check that first :)
lol tried that and still staying on!!
ANYONE??? :-)
It looks like you're gonna have to start at the headlight plug with a multi meter and work backwards testing the wires, you might have some corrosion in 1 or more connectors allowing the light to get a permanent live feed.
It looks like you're gonna have to start at the headlight plug with a multi meter and work backwards testing the wires' date=' you might have some corrosion in 1 or more connectors allowing the light to get a permanent live feed.
great I hate electrics
today we spent ages today trying to sort it but couldn't, so far I have tried a different light switch, indicator stalks, different real light clusters, pulled every relay out and cleaned some earths and its still bloody staying on, ive pulled out fuse 21 to stop it draining the battery.
any ideas as im totally stuck now????
Why fuse 21? That's for interior light, central locking and sunroof.
If you've pulled the headlight fuse and the light has gone out you at least know that the fault doesn't lie from the fuse box to the lights, its somewhere up to the fuse box.
