mawrick 0 Posted May 17, 2013 Report Share Posted May 17, 2013 I'v had this problem since I bought the car, and realy never looked into it to much, but want to get it sorted - so if anyone got any idea where I might start feel free to chime in.Here is a video with the temp-sensor disconnected (Yellow temp sensor)http://s16.photobucket.com/user/Mawrick/media/13050049_zps2cf9e72f.mp4.htmlHere is a video of the cluster when the temp sensor have been connected again:http://s16.photobucket.com/user/Mawrick/media/13050050_zps46aa5c11.mp4.htmlIt will do the same from a complete cold start (on video oil temp was around 60 C).I'v confirmed the cluster is working (in another car), and also checked with another cluster in the corrado with same result.From the vide it seems like it will add a tiny bit to the temp when the sensor is connected, and also the needle seem to rise a bit faster.Anyone ever encounter such a problem ? - or have any clues where to start??????The car is a 95 VR6 Link to post Share on other sites
VR6Pete 1,455 Posted May 17, 2013 Report Share Posted May 17, 2013 Hey, this is odd... I wouldn't expect the needle to raise with the sensor disconnected, if you have put another cluster in your car and it still does the same makes me think there is a fault somewhere. The only thing I can recommend is to start tracing wires back from the clocks.... A Bentley would be handy, the wiring diagrams are pretty good.I'm sure someone else will have some ideas... Link to post Share on other sites
mawrick 0 Posted May 17, 2013 Author Report Share Posted May 17, 2013 Yea, I'm trying to figure out the wiring in the bentley...........for me it looks like there is only a wire running directly to the sensor, and not going thru the ECM unit.I'l have to have a closer look at this - it's bugging me (I presume the Track numbers in the bentley is only to make it easier to trace it - and not actuall points on the car ??) Link to post Share on other sites
mawrick 0 Posted May 17, 2013 Author Report Share Posted May 17, 2013 Just thought I'd add a picture I made on how I read from the bentley - and maybe someone can confirm if I'm right or wrong - when it comes to the wiring of the Yellow temp sensor: Link to post Share on other sites
mawrick 0 Posted May 20, 2013 Author Report Share Posted May 20, 2013 After much troubleshooting I finaly found the culprit!...............hard to track down, very easy to fix....lol (was thinking this is gona be an easy fix).Turns out some former owner must have messed with the relay layout, or added a relay that's not supposed to be there - at least of wrong type.They had put relay number "72" into relay slot nr 5 - where 43 or "open" is supposed to be.....This caused it making a circuit over the coil in the relay, feeding the gauge a false signal......Ohh, well that's out of the way! Link to post Share on other sites
VR6Pete 1,455 Posted May 20, 2013 Report Share Posted May 20, 2013 Blimey! You'd never have guessed that in a million years! Link to post Share on other sites
