Woodyman84 3 Posted June 2, 2013 Report Share Posted June 2, 2013 Right the cutting out kangaroos continues. Had new fuel filter an mafNo fault codes.It seems now that this only ever happens from a hot start. Ie car been off for 10 mins or less.It will then try to stall, like a momentary loss of power. Rev an Speedo also die.Any clues or suggestions welcome, driving me mad now. So intermittent Link to post Share on other sites
michael5556 247 Posted June 2, 2013 Report Share Posted June 2, 2013 Blue temp sensor? Once it gets up to temp? Not lambda, my first guess would of been maf. Is it a new Bosch one? Link to post Share on other sites
Woodyman84 3 Posted June 2, 2013 Author Report Share Posted June 2, 2013 Yeh genuine one, I'll have a read up on blue temp sensor thanks Link to post Share on other sites
Radosteve 12 Posted June 2, 2013 Report Share Posted June 2, 2013 This sounds like what's happening to me , vag com flagged up it was my intake manifold temp sensorBosch pn- 52180. Oem number - 0 280 130 039 . Will be getting one ASAP cause it was really bad today Link to post Share on other sites
UnitedMotorsport 55 Posted June 2, 2013 Report Share Posted June 2, 2013 It will then try to stall' date=' like a momentary loss of power. Rev an Speedo also die.[/quote']This points to an electrical problem. Link to post Share on other sites
Woodyman84 3 Posted June 2, 2013 Author Report Share Posted June 2, 2013 Good point um, I can also hear a relay click on and off. I need to pay attention next time to if the whole cluster is dying or just dials. I'd have thought any electrical short shud throw a code.Definately another avenue to explore. Could it be the relay itself playing.up? Link to post Share on other sites
Woodyman84 3 Posted June 2, 2013 Author Report Share Posted June 2, 2013 Just had a brainwave on the electrical side. It's intermittent and quite random.Could it be a faulty ignition switch, worn contact playing up? I've also had a few puffs of smoke from steering console recently but hadn't linked the two??? Link to post Share on other sites
Woodyman84 3 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Did it again this morning, barely made it to work after stopping at garage then restartingThe only part of the cluster that dies is the Revometer, everything else stays fineFiddled with ignition switch seem to make no differenceI pulled over and everytime i revvd the car the relay clicked like mad an revs kept dropping sharplyi think i really need to find out what relay is clicking as may give me some clues Link to post Share on other sites
Woodyman84 3 Posted June 3, 2013 Author Report Share Posted June 3, 2013 http://www.edition38.com/forums/index.php?showtopic=284265sorry to link another forum but this sounds exactly like my problem Link to post Share on other sites
Daverse 175 Posted June 3, 2013 Report Share Posted June 3, 2013 I'd certainly loom at that, because if it does start cutting out for longer the steering lock could come on.. Link to post Share on other sites
Woodyman84 3 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Just need to replicate the fault now an play guess the relay Link to post Share on other sites
UnitedMotorsport 55 Posted June 3, 2013 Report Share Posted June 3, 2013 If the car is OBD1 then I guess its relay 109, position 3 in the relay plate. Third from the left on the top row. Link to post Share on other sites
Woodyman84 3 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Ah bugger just seen.that. Mine is ob2, I assume that's goin to make a difference.Once again appreciate all the help guys an sorry for all the questions Link to post Share on other sites
UnitedMotorsport 55 Posted June 3, 2013 Report Share Posted June 3, 2013 Then the only relay that can be affecting the running of the engine (aside from main power relays) is the fuel pump relay in position 12, bottom row first from the right.Something not obvious to check is the wiring to the lambda probe, see if it is damaged and shorting out. Link to post Share on other sites
Woodyman84 3 Posted June 3, 2013 Author Report Share Posted June 3, 2013 It's definitely fuel pump relay managed to put hand on it while driving. It's gettin alot worse as well. Just hope it's just the relay an I hope it gets me to the parts shop.Good call mate! Link to post Share on other sites
Trickygti 3 Posted June 3, 2013 Report Share Posted June 3, 2013 edit: nevermind didnt see page 2 haha Link to post Share on other sites
Woodyman84 3 Posted June 3, 2013 Author Report Share Posted June 3, 2013 I've been reading up an if the relay don't fix it then it could be ground fault to ecu or worse. The fuel pump itself is shorting out. Although I can't see how that effects the relay circuit. Gettin New relay tommorow morning Link to post Share on other sites
Woodyman84 3 Posted June 4, 2013 Author Report Share Posted June 4, 2013 Relay changed. Fault remains the same :-( Link to post Share on other sites
UnitedMotorsport 55 Posted June 4, 2013 Report Share Posted June 4, 2013 Did you check the lambda probe wiring? Link to post Share on other sites
Woodyman84 3 Posted June 4, 2013 Author Report Share Posted June 4, 2013 I'm afraid to say I'm a total idiot. Once again the fault was caused by my own stupidity!Checking earth an I noticed the neutral battery terminal was not tightened up from last time I took it off!!!Tightened it up an it's been fine since!Guess it was just expanding when warm an losing contactU all have my.permission to slap me at the rr day! Link to post Share on other sites
VR6Pete 1,455 Posted June 4, 2013 Report Share Posted June 4, 2013 Loo. You muppet Link to post Share on other sites
Daverse 175 Posted June 4, 2013 Report Share Posted June 4, 2013 Least you didn't weld a spanner to the batteries, usually what i end up doing!Glad its sorted now for you Link to post Share on other sites
Woodyman84 3 Posted June 4, 2013 Author Report Share Posted June 4, 2013 My Mrs said...see all u do is break it leave the f,ing car alone!!! She's got a point! Link to post Share on other sites
Toddy 8 Posted June 7, 2013 Report Share Posted June 7, 2013 The steering lock won't engage as long as the key is still in it.I'd replace the ignition switch and check all your earths. Especially the engine bay ones inc from the Coil. Link to post Share on other sites
