vr6 done top mounts, which position do you put the suspension back into the hub?
I didn't mark anything but my front tyres need replacing anyway, I notice when you put the standard suspension back into the hub there are various positions you can tighten it up into, adjustable camber reasons I guess, what way is correct to put the two18mm bolts into the hub so the tyres wear even?? pushing the disk towards the suspension strut or pulling it further away from the suspension strut?
best regards :)
thank you guys. I will get this done!!!
I have play in my anti roll bar drop links, replaced these years back. is it a case of just dropping the wishbone from the hub and taking the old drop links off, cant remember!!!
(6)
The drop links are just connected to the wishbone by a 13mm bolt' date=' no need to remove the wishbone.
but there is not enough room to spin them off or will the ARB drop when you disconnect the link?
