  • Replies 384
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Finally got the engine back few more bits and it can go in :-)
Boost pipes are all cut and made ready to go on not much left now :-)
I'll throw a few pics up of what has been done :-) And that is how it's sits waiting for paint :-)
Posted Images
Spec stage 3+ isnt a bad clutch for 300-400 whp. A friend of mine have had his 3+ since 2008. Only 10 psi/stock 10:1 cr.
And since the others are so kind to give you a upgrade tip on bent clutch forks, take a look here to get an idea:
That's good to here and thanks for the link :)
http://forums.tdiclub.com/showthread.php?t=248789&page=2
you guys should check the syvecs gp ecu  you can add cal switch with 8 maps for turbo cars
has all sendor layout and has warning cut off for oil pressure temp ,water etc can control solenids and magnets for dccd and I think it should control the haldex quite easily by tps rpm wheel sensor speed and brake pressure
also controls boost like a ruler  ..
can control upto 8 cylinders ,
awesome ecu worth its weight in gold ..
