djmac 1 Posted June 30, 2013 Report Share Posted June 30, 2013 Hi, id just recently taken my inlet manifold of to paint, but now after i give the car some power it begins to smoke alot out of the rear can and sometimes from the fins on the down pipe?Have i done something wrong when refitting as im sure there was never this issue before?Could this be a common fault and a simple fix?Thanks alot Dan Link to post Share on other sites
Lukey. 381 Posted June 30, 2013 Report Share Posted June 30, 2013 Did you use wd40 or anything as that would burn off Link to post Share on other sites
djmac 1 Posted June 30, 2013 Author Report Share Posted June 30, 2013 i did use a form of lubrication but thaught it must have burnt off by now! I think the best thing is to take apart and refit to check for any damage!Thanks for the response Link to post Share on other sites
VR6Pete 1,455 Posted June 30, 2013 Report Share Posted June 30, 2013 Sometimes oil collects in the inlet from PCV, is it possible upon removal it has proceeded to go down the inlets? Link to post Share on other sites
wardycatt 7 Posted July 1, 2013 Report Share Posted July 1, 2013 Could one of the coolant pipes off the throttle body have been dripping down between the heatshield and the exhaust pipe, near to where the pipes come together (i.e. after the exhaust manifold)?I did some work on the inlet manifold, and then had all sorts of smoke coming out the engine bay and under the car, for the first 15-20 minutes of running it. I thought something like coolant or lubricant would burn off quickly, but it only really starts evaporating once the exhaust heats up properly. I did crap myself at the time. Give the smoke a sniff (don't get high!) - if it's white-ish in colour and doesn't smell of oil then the chances are it's coolant. If you removed the two pipes from the throttle body and didn't clamp them / tie them completely out the way, then one of them has a decent chance of dripping directly into the gap between the exhaust and heatshield. The smoke would be primarily focused towards the back of your engine bay, but was coming from under my car and at the tailpipe of the exhaust also. If the smoke is correlated to you applying power (i.e. more power equals more smoke), then something's getting in to the combustion chamber and it's nothing to do with the above. If it's a general smokiness after about 30-60 seconds of starting up, which doesn't get any worse under engine load, then it just might be some residual coolant. I just let mine idle for a while and the smoke gradually went away. Link to post Share on other sites
