Hi all, New to the vr6 scene and heard they run very hot most of the time! But i wasnt sure if that was too hot, 98oC! I know it is warm in the UK atm, but is that correct? The fans do come on, but sound abit iffy so wondering weather i just need some new fans?
Cheers Dan
I would presume you are referring to oil temperature here? If so 98 is acceptable, especially in the current hot climate. Unless you have had the car on Vagcom at the time it would be hard to gauge the coolant temperature at exactly 98 degrees.
To test fans you need to bridge from the middle pin on the fan switch plug. Pin 2 is your feed with pin 1 & 3 the low and high speed respectively. If you're in doubt check with multimeter. If only one fan is working the little drive belt between the fans is maybe missing or broken.
