Shaneomac116 0 Posted July 27, 2013 Report Share Posted July 27, 2013 Hey guys, my mk3 vr6 has started leaking water, it seems to build up pressure and squeezes all the coolant out of the joins on the coolant hoses but it doesn't overheat. Anybody got any ideas as to what the problem could be? Link to post Share on other sites
Lukey. 381 Posted July 29, 2013 Report Share Posted July 29, 2013 Are you using the original spring clips? If so change them for jubilee clips first and see if the leaks stop. Link to post Share on other sites
Jimjon 28 Posted July 29, 2013 Report Share Posted July 29, 2013 I just had this on mine and it was the head gasket had gone and was pushing air into the cooling system and pressurising it, but i also had a symptom of it running a bit rough on startup for a few seconds as 1 cylinder was filling with water when left overnight. Link to post Share on other sites
Lukey. 381 Posted July 29, 2013 Report Share Posted July 29, 2013 To check for that you can get a sniff test done to check for exhaust gasses in the cooling system. Link to post Share on other sites
