psilosimon 8 Posted July 27, 2013 Report Share Posted July 27, 2013 The VR has started with an intermittent weirdness with the ABS. Braking works fine under 99% of braking conditions, but now and then grinds to a halt with a graunchy noise when braking softly, especially under right hand full lock - say turning into a carpark or summat.I can't see owt obviously loose or worn.any ideas? Link to post Share on other sites
VR6Pete 1,455 Posted July 28, 2013 Report Share Posted July 28, 2013 Brake shield hitting the disk?Might be worth scanning with vag com for any sensor faults too, I had a dodgy once and it used to make my drivers wheel lock up going around left hand bends Link to post Share on other sites
psilosimon 8 Posted December 10, 2013 Author Report Share Posted December 10, 2013 At first I thought it was a brake problem, like I said - right hand lock over slight bump - thought maybe an airbubble in the flexy. but now I'm thinking it could be the abs or traction control, sometimes it does it without using the brakes, and sometimes if you gun it when roads are wet its like the traction control slips slightly.The ABS light comes on at start up and goes out as normal. Link to post Share on other sites
VR6Pete 1,455 Posted December 16, 2013 Report Share Posted December 16, 2013 At first I thought it was a brake problem, like I said - right hand lock over slight bump - thought maybe an airbubble in the flexy. but now I'm thinking it could be the abs or traction control, sometimes it does it without using the brakes, and sometimes if you gun it when roads are wet its like the traction control slips slightly. The ABS light comes on at start up and goes out as normal. Ahhh. Could be an intermittent faulty wheel speed sensor. I had an issue on my old mk3 where going around right hand corners would cause the ABS to kick in. Maybe vag-com may shed some light which one is playing up ? Club Chairman Link to post Share on other sites
psilosimon 8 Posted December 17, 2013 Author Report Share Posted December 17, 2013 ok, will have to try that. Will let you know the outcome. ... just need Vagcom Link to post Share on other sites
VR6Pete 1,455 Posted December 17, 2013 Report Share Posted December 17, 2013 ok, will have to try that. Will let you know the outcome. ... just need Vagcom Where abouts are you located mate? Sent from my iPhone using Tapatalk Link to post Share on other sites
psilosimon 8 Posted December 18, 2013 Author Report Share Posted December 18, 2013 Plymouth Link to post Share on other sites
Surreyvr6 199 Posted December 20, 2013 Report Share Posted December 20, 2013 Sorry to steal your thread about your abs but I'll be moving to Plymouth area once we've got dates to move into new house, is there much in the way of meets of anything in the area? Sent from my iPhone using Tapatalk VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted December 20, 2013 Report Share Posted December 20, 2013 Sorry to steal your thread about your abs but I'll be moving to Plymouth area once we've got dates to move into new house, is there much in the way of meets of anything in the area? Sent from my iPhone using Tapatalk Would love see some regional meets being set up any volunteers? Club Chairman Link to post Share on other sites
Surreyvr6 199 Posted December 20, 2013 Report Share Posted December 20, 2013 (edited) Would be up for it but I'm not going to be in my area long, won't know anyone in my new area and my as well have dropped my trouser when I took my motor for its mot yesterday so may not be on the road for a while lol, when I'm up and running I'd be up for it Sent from my iPhone using Tapatalk Edited December 20, 2013 by Surreyvr6 VR6Pete 1 Link to post Share on other sites
