Turbo_T 0 Posted July 29, 2013 Report Share Posted July 29, 2013 Hi all i have a 4motion turbo and looking to see if there any others on here for some help and advice Ton y Link to post Share on other sites
Swivelonit 119 Posted July 29, 2013 Report Share Posted July 29, 2013 I have a 4 motion, I also have a turbo but they haven't met yet! I have 90% of what I need to turbo the car, just looking for head spacer and inlet manifold, or should I say I have found them I just have to fund them. Post up a bit more about your motor, would be of interest. Link to post Share on other sites
craggsy 91 Posted July 29, 2013 Report Share Posted July 29, 2013 What do you need to know as there may not be owners of that car, but there are some knowledgable people on here to help Link to post Share on other sites
Turbo_T 0 Posted July 30, 2013 Author Report Share Posted July 30, 2013 well it was converted a few years ago i think and has had a hard life lol im not 100% on everything but its running a GT30 turbo has uprated injectors (not sure which) Apexi SAFC2 external wastegate with a screamer pipe i think and uprated clutch Its has a second hand engine fitted recently (not 100% why) but this is a standard engine so im looking to sort a head spacer as sure its not good running without it its running the standard map still so looking to get it remapped and its been setup using the SAFC2 but think someone has messed that all up as its not quick and dont like boosting in the lower gears im used to cars that are made turbo'd and then doing them up so buying one thats had a turbo stick on and not really been setup for it is new to me lol Link to post Share on other sites
craggsy 91 Posted July 30, 2013 Report Share Posted July 30, 2013 So bigger injectors on an unmapped car?No wonder its not running right, will be overfueling.Probably knackered the previous engine because of it. Link to post Share on other sites
Turbo_T 0 Posted July 30, 2013 Author Report Share Posted July 30, 2013 thats what im thinking if i can get a chance and its not that hard to do i will try get to the injectors and see what thay are Link to post Share on other sites
Turbo_T 0 Posted August 2, 2013 Author Report Share Posted August 2, 2013 gone quiet on here lol well bit more update info when i got the car home i plugged vagcom in and found 32 fault codes lol i cleared them all and rerun the car and 11 came back i since been working on sorting them and got it down to 5 now , 2 which are lambdas which ive ordered 1 a abs sensor which i have now 1 is steering angle fault and other is secondary air pump reply ( which is missing lol ) so by middle of next week i should only have the 2 last codes left then ill strip it down and check injectors and hopfully get a remap booked Link to post Share on other sites
craggsy 91 Posted August 2, 2013 Report Share Posted August 2, 2013 Steering angle sensor is on the steering wheel.The air pump will always throw a fault if it ain't there, I think they need to be mapped out Link to post Share on other sites
Turbo_T 0 Posted August 3, 2013 Author Report Share Posted August 3, 2013 yeah i had 3 codes for the secondary air system but 2 ive sorted with resistors the angle sensor im going to try recalibrate one day and see if that fixes it Link to post Share on other sites
Turbo_T 0 Posted August 13, 2013 Author Report Share Posted August 13, 2013 well few updates spoke to jim last week and will be meeting him soon to take a look at the car and hopefully get some new mapping and need to get a head spacer fitted been doing few bits to the car fitted 2 new rear calipers as they was sticking on also changed the thermostat housing as this had a crack in it fitted 2 new lambdas but might have to have play with theses as seems i only have 3 fitted lol fitted 1 new tyre today as the tennis ball growing out the sidewall was starting to get Bigger also removed carbon canister and ordered a washer bottle as mine been removed for the turbo pipework Link to post Share on other sites
Lukey. 381 Posted August 13, 2013 Report Share Posted August 13, 2013 All sounds like steady progress. Link to post Share on other sites
adriandealone 1 Posted October 11, 2013 Report Share Posted October 11, 2013 Hi guys i'm new to the forum and all the car stuff....I also have a v6 4motion AUE looking to tubo it. I got a garrett gt35/40r by mistake(long story). I was told to do engine rebuild before I go turbo, so I found a gen 1 haldex controller, got big break conversion (tarox 6pot) also my master cylinder went so I was advised if going turbo do clutch so as we speak I'm having a clutch master fx850 with aluminium flywheel. I'm hoping some advice also on parts I want to get.....with my current turbo (not fitted) I'm looking for 450ft/tq maybe more... but my question is what wastegate should I get? Link to post Share on other sites
bungy 2 Posted December 1, 2013 Report Share Posted December 1, 2013 well it was converted a few years ago i think and has had a hard life lol im not 100% on everything but its running a GT30 turbo has uprated injectors (not sure which) Apexi SAFC2 external wastegate with a screamer pipe i think and uprated clutch Its has a second hand engine fitted recently (not 100% why) but this is a standard engine so im looking to sort a head spacer as sure its not good running without it its running the standard map still so looking to get it remapped and its been setup using the SAFC2 but think someone has messed that all up as its not quick and dont like boosting in the lower gears im used to cars that are made turbo'd and then doing them up so buying one thats had a turbo stick on and not really been setup for it is new to me lolDo you know what size injectors you are running as you are more likely than not over fueling which will cause bore wash and premature engine failure. Also running high compression will give adverse affects. Link to post Share on other sites
craggsy 91 Posted December 1, 2013 Report Share Posted December 1, 2013 Jim will give you solid advice Link to post Share on other sites
Swivelonit 119 Posted December 1, 2013 Report Share Posted December 1, 2013 Steering angle sensor, I had that issue, I ended up using VCDS to re calibrate it, I then got an ABS warning light, I had to sit in a large car park, press the foot brake firmly down until the ABS light started to flash, once flashing drive the car under 15 mph whilst steering from lock to lock, after a few turns the light went off and everything was set. Injectors, I have got 630cc or 60lb depending in where you live. Link to post Share on other sites
bungy 2 Posted December 1, 2013 Report Share Posted December 1, 2013 Steering angle sensor, I had that issue, I ended up using VCDS to re calibrate it, I then got an ABS warning light, I had to sit in a large car park, press the foot brake firmly down until the ABS light started to flash, once flashing drive the car under 15 mph whilst steering from lock to lock, after a few turns the light went off and everything was set. Injectors, I have got 630cc or 60lb depending in where you liveI've got 630's in mine and they needed settings changed. Link to post Share on other sites
Swivelonit 119 Posted December 1, 2013 Report Share Posted December 1, 2013 (edited) Yes, I know, once the new injectors go in and the turbo fitted a lot of settings need changing.. Remap etc Edited December 1, 2013 by Swivelonit Link to post Share on other sites
