tasja 0 Posted April 23, 2005 Report Share Posted April 23, 2005 my car sounds like it is running of 4 cylinders instead of 6 think it is my injectors. i have done almost everything else from changing plug leads to buying a new coil pack even chaning the afm.please help Link to post Share on other sites
HerbertVR6 0 Posted April 23, 2005 Report Share Posted April 23, 2005 Why dont you try some redex injector cleaner? :? That should do it.HerbertVR6[ Edited Sat Apr 23 2005, 07:59AM ] Link to post Share on other sites
acf8181 0 Posted April 23, 2005 Report Share Posted April 23, 2005 have you plugged in diagnostics? i think it would show up any injector probs. Link to post Share on other sites
ingham 5 Posted April 23, 2005 Report Share Posted April 23, 2005 i wouldnt spend a penny until you have plugged in diagnostics like acf says Link to post Share on other sites
Winks 0 Posted April 24, 2005 Report Share Posted April 24, 2005 My cars the same when cold sounds like theres a plug out, better when hot but still there!When you let it idle almost goes away but as soon as you take the revs up back it comes.Have changed the following in this order:Plugs-LeadsVW Tech scan showed G40 Hall sender, Changed (still there)Coil PackChain Tension boltVW Tech scan again no faults showing!!!!!!!!Still there!!!!!!!!Cleaned:Air Flow MeterThottle BodyHas any one got any ideasHelp before I go insane!!!!!!!" Link to post Share on other sites
acf8181 0 Posted April 24, 2005 Report Share Posted April 24, 2005 so, winks, you changed the hall sender...but the fault code remained? if so, it could be wiring, or it coudl be the magnet on the sproket (this is what happened to mine) Link to post Share on other sites
Winks 0 Posted April 25, 2005 Report Share Posted April 25, 2005 No, fault code has gone but still sounds like it has a mis-fire still. Link to post Share on other sites
acf8181 0 Posted April 25, 2005 Report Share Posted April 25, 2005 then it wasn't hall sender casuing it.i'd look at leads and coilpack first (spray water over them at night with engine running and look for sparks)...also check for any damaged vacuum tubes (theres one that goes from throttle body to airbox that can easily get burnt on ex manifold)...amd if its obd1 clean the ISV. Link to post Share on other sites
