Daverse 175 Posted August 18, 2013 Report Share Posted August 18, 2013 How do guys So, the story goes that my golf blew a head gasket a while ago, more like a year ago! Been very busy. Anyways finally got it all built back up again, but the fuel pump isnt priming, and it isnt getting a spark, would a clifford alarm cut the coil and fuel pump? Any other ideas? Cheers chaps Link to post Share on other sites
VR6Pete 1,455 Posted August 18, 2013 Report Share Posted August 18, 2013 Possible. When my clifford is immobilised I don't get get anything... No dash lights, power to aux pump, throttle body etc....Do you get anything at all? Check your in-line fuses on your clifford?Usually it chirps once and the clifford blue LED goes out when it's dis armed.... check the big engine multi plug in the engine bay, make sure it's properly connected I have the clifford software and cable (40 quid off eBay) you can plug it in and it will tell you exactly what state the alarm is in....Are you able vag-com it or is it totally dead? Link to post Share on other sites
Daverse 175 Posted August 19, 2013 Author Report Share Posted August 19, 2013 Dashboard all lights up fine, hear the throttle body adjust e.t.c and cranks fine just nothing else Link to post Share on other sites
Daverse 175 Posted August 19, 2013 Author Report Share Posted August 19, 2013 Vag com comes back with nothing, i'll do a proper write up tonight when im off my phone Link to post Share on other sites
Daverse 175 Posted August 19, 2013 Author Report Share Posted August 19, 2013 So basically with the alarm, It will arm and flash the hazards when i unlock the door e.t.c, (and turn the wipers on for some reason??) the red clifford LED thats been mounted below my cd player flashes, the ignition comes up fine, and displays the message "LN02" which i believe just means inspection? it will crank and sound ok, but its just doesnt fire!? when the ignition is on i can hear the throttle body align, but i cant hear the fuel pump prime, but was working perfectly fine before? vag com displays no issues, and when i took the spark plug out i couldnt see it arcing, even on a different known coil pack. any ideas? Link to post Share on other sites
VR6Pete 1,455 Posted August 19, 2013 Report Share Posted August 19, 2013 Mmm. Could be a bad earth? Link to post Share on other sites
Daverse 175 Posted August 21, 2013 Author Report Share Posted August 21, 2013 Hmm could be, dont they show up on vag com though? Link to post Share on other sites
