shail 0 Posted April 26, 2005 Report Share Posted April 26, 2005 im looking to buy a new head unit. Ive seen a bunch with 'Dedicated sub-preout RCA'.What is this? Is it a normal pre-out but only sends low fequencies which you need to plug into an amp?, or do you connect it directly to the sub? Either way what are the benefits? Ive currenlty got an amp running front comps and another running a 10" sub. Link to post Share on other sites
badboyV6 4 Posted April 26, 2005 Report Share Posted April 26, 2005 Basically this is what you want if your going to run a sub- you can adjust the amount of power you send the sub from the head unit. I had 2 amps in my last vr one 800W running 2 x 12" and another running rear and front door components. You could eassly adjust the amount of bass depending on the type of music i was playing.... Link to post Share on other sites
Eat this 2 Posted April 26, 2005 Report Share Posted April 26, 2005 it a normal pre-out but only sends low fequencies which you need to plug into an ampyep! Link to post Share on other sites
badboyV6 4 Posted April 26, 2005 Report Share Posted April 26, 2005 said everything else apart from the low frequency bit! -doh! Link to post Share on other sites
scoobysmiff 0 Posted May 3, 2005 Report Share Posted May 3, 2005 not many headunits have a cross over on the sub out (most of the higher spec pioneer ones do though) you will find that all it is, is a non fading output ie it don't matter where the balance or front/rear fader is set you will still get the same level of output to the subs. you should have a level adjustment (which effectively adjusts the volume) on it though which will be controlable from the headunit Link to post Share on other sites
acf8181 0 Posted May 4, 2005 Report Share Posted May 4, 2005 as scoobysmiff says....my kenwood has one and it does make it easier to adjust sound to different tunes, bt its not essential. Link to post Share on other sites
