c00k 435 Posted May 18, 2015 Report Share Posted May 18, 2015 (edited) Engine look good buddy, What sort of power are you hoping for with new turbo dude? Edited May 18, 2015 by c00k Link to post Share on other sites
Russvrt 85 Posted May 18, 2015 Author Report Share Posted May 18, 2015 Thanks will run it at 1 bar should be just over 400 or there abouts ..plenty! I'm thinking about breaking my daily 8v corrado when I get back off holiday to fund finishing this off how I want it.. daveyboy 1 Link to post Share on other sites
Russvrt 85 Posted June 26, 2015 Author Report Share Posted June 26, 2015 Should have a good update tomorrow ,as long as my bm doesn't have any problems with its mot( just checked paperwork and it ran out last week ,oops)so it's in for a last minute test in the morning if all goes well I'm playing corrado for the rest of the day,things have changed since last update but just boring stuff.. Link to post Share on other sites
lilfuzzer 48 Posted June 27, 2015 Report Share Posted June 27, 2015 looking forward to update Russ Link to post Share on other sites
daveyboy 897 Posted June 27, 2015 Report Share Posted June 27, 2015 Then you'll have enough time to get your arse upto Newcastle to sort my wiring for my 24v russ lol Link to post Share on other sites
Russvrt 85 Posted June 27, 2015 Author Report Share Posted June 27, 2015 Then you'll have enough time to get your arse upto Newcastle to sort my wiring for my 24v russ lolThe way things are going I won't be helping anyone ..What a day,,,my plan was to have the engine bolted back in this aft so I could order the bits to change my down pipe and one boost pipe to be v banded...This didn't happen,,first off the bm only just past it's mot so there's a few bits I needed to sort on that,,,then finally got to work on the rado,,,happy days,started off well got the steering rack and arb all bolted up to the subframe ,then came the wishbones with fresh tt rear bushes and powerflex fronts,one side went on fine then as I put the front bolt in the other side it went straight through ,no thread great ,stripped it down again and put some weld in the hole so I can drill and tap it( these are at work so had to carry on without the bolt in) then when fitting the subframe to the car 3 of the bolts would not! go in so these need tapping out too...So moved on to the engine ,put engine mounts,starter motor( upside down as it looks cleaner) then gave up..Didn't get many pics but will put up what I took later,Hopefully next time I can get the engine in .. Link to post Share on other sites
Russvrt 85 Posted June 27, 2015 Author Report Share Posted June 27, 2015 Sorry for the rant daveyboy 1 Link to post Share on other sites
