I have a 97 golf vr6. I recently had all my mounts replaced front, rear and gearbox just originals from GSF as I couldn't afford the vibra technics ones.
When I look at car from the front my engine sits high at the back left sloping to the front right. I never noticed if it was like this before my mounts were replaced and needed some help as to whether this is right or indicates a problem with mounts or their fitting???
When I had the mounts fitted I also had the steering rack and the clutch changed, and I fitted powerflex bushes to the wishbone. I had a number of bumps and creaks that these items were supposed to fix but they have become a knock/click when any poke is applied and a knock when the clutch is engaged or disengaged with differing revs.
It's a project car that I have been repairing and speccing up so it's always had something knocking or bumping and I have been working through this list. Am I lucky enough that the mounts are incorrect in some way and this is causing the engine to not sit level and consequent noises??? Or is this something worse? The diff?
I have put a pic of the engine from the front to show the lean? Can someone help please?
post-93223-0-78118100-1382363135_thumb.j
This is mine (sorry it's dark!) I had my mounts changed recently and only issue was the front mount (gsf) part had too long a thread and wasn't bolted down properly on the front so felt like the engine was coming through the bulk head, this was missed by a supposed mechanic and wasn't noticed until I changed the front insert to a poly one.
Hope this is of use.
Stevepost-87425-0-92583900-1382379461_thumb.j
Hi Mate, German Ebay search for motolager. it was a street (60 shore?) PU insert. thats the only one i did, the side mount is OEM and the gearbox mount was changed to a solid G60 one (recommended on other site)
http://www.ebay.de/itm/Motorlager-vorn-Polyurethan-PU-Lager-Golf-3-GT-GTI-8V-16V-VR6-schwarz-street-/321100697479?pt=Teile_ohne_Strassenzulassung&hash=item4ac317cf87
http://www.vwspares.co.uk/product_info.php?products_id=608
enjoy.
steve
