Edgeyboy 3 Posted October 31, 2013 Report Share Posted October 31, 2013 Hi all. I wanted to know if anyone could help..... I have replaced my ABS sensors on my 95 golf vr, yet when i plug my laptop in it comes up with no response from controller on the ABS section... Does this mean my whole ABS system is shot or is it something simple??Please help.Cheers.Edge. Link to post Share on other sites
cactusjackslade 146 Posted October 31, 2013 Report Share Posted October 31, 2013 That's basically saying that the abs controller or ecu is not responding / talking to your diagnostic equipment. you arn't even accessing the ecu to read any fault codes. Start with basics first. check for blown fuses and that the large plug on the abs controller itself is plugged in and connections are clean. can you access orther ecu's on the vehicle ok e.g. engine managment system?? Link to post Share on other sites
shawy 3 Posted October 31, 2013 Report Share Posted October 31, 2013 Either loss of power to the and pump, or pump is faulty ..Or ur computer won't speak to the pump ... have u plugged it into abs before .. Link to post Share on other sites
Edgeyboy 3 Posted November 2, 2013 Author Report Share Posted November 2, 2013 Hi.Ye i can access all the other sections that i have available, jus not the ABS one. I will try the relays and fuses today and see where i go from there.Failing that, is the ABS pump a difficult swap?Regards Link to post Share on other sites
