So after having owned my R32 for 4 years I decided it was time to bite the bullet and go big, luckily ive fallen on my feet several times when buying parts for my car including the turbo kit which I got at almost half the RRP!
Anyway heres my car
C307C25F-C0D5-4703-B0A1-FFE345A9341A-881
Spec.
Engine: 3.2L VR6 with Garrett GT30 Roller bearing turbocharger with HGP casing, open bottom airbox with pipercross panel filter, Neuspeed lightweight pulleys, HGP Short runner inlet manifold, Modified 3" HGP downpipe into custom made 3.5" exhaust with bypass system, Larger MAF, Twin Leon Cupra R Side mounted Intercoolers, HGP 465 mapping, Head spacer, Second inline fuel pump, fully rebuilt engine with new bottom end and replaced timing chains.
Trans: Sachs sintered clutch with Single mass flywheel, HPA Shortshifter, 42DD solid shifter bushes, Nm2b Wotbox
Suspension: Bilstein B14 PSS Coilovers, Nuespeed Race Front & Rear ARBs, Custom made adjustable tie arms, Audi S3 upper & lower strut braces, Unibrace XB
Brakes: Audi B7 RS4 8 pot calipers with custom made rotor hats and Audi 365mm drilled rotors
Other: Audi R8 oil cap, Porsche coolant cap, H&R 10mm spacers up front with 20mm on the rear, Matte black front grille, US Spec taillights, Mk5 Rear wiper, Seat Cupra Splitter, VW R Line centre caps.
Ill add a few more progress pictures in a bit :)
