JamesB 6 Posted November 3, 2013 Report Share Posted November 3, 2013 Name: VW Golf Mk4 (2003)Date Added: 03 November 2013 - 07:52 PMOwner: JamesBShort Description: R32 HGP Turbo.3.2L VR6 with Garrett GT30 Roller bearing turbocharger with HGP casing, open bottom airbox with pipercross panel filter, Neuspeed lightweight pulleys, HGP Short runner inlet manifold, Modified 3" HGP downpipe into custom made 3.5" exhaust with bypass system, Larger MAF, Twin Leon Cupra R Side mounted Intercoolers, HGP 465 mapping, Head spacer, Second inline fuel pump, fully rebuilt bottom end and replaced timing chains. Trans: Sachs sintered clutch with Single mass flywheel, HPA Shortshifter, Long Ratio Diesel Gearing, 42DD solid shifter bushes, Nm2b Wotbox Suspension: Bilstein B14 PSS Coilovers, Nuespeed Race Front & Rear ARBs, Custom made adjustable tie arms, Audi S3 upper & lower strut braces, Unibrace XB Brakes: Audi B7 RS4 8 pot calipers with custom made rotor hats and Audi 365mm drilled rotors Other: Audi R8 oil cap, Porsche coolant cap, H&R 10mm spacers up front with 20mm on the rear, Matte black front grille, US Spec taillights, Mk5 Rear wiper, Seat Cupra Splitter, VW R Line centre caps, Zada Tech Multi-gauge built into instrument cluster.View Vehicle VR6Pete 1 Link to post Share on other sites
