Benbeaver 1 Posted November 5, 2013 Report Share Posted November 5, 2013 I had my mk3 vr6 into volksautos for some work to diagnose a clunk when I came on and off the power or clutched in our out at different revs. They have said the problem is that one of the bolts on the plate below the engine mount has sheered. I ordered a replacement crossmember and hoped that would solve the problem. My replacement crossmember doesn't seem to have any studs on the bottom or holes, it's supposed to of come off a GTI and when I looked on vagcat it looked like there was only 1 type of engine support set up. Have I got the wrong part? Can I use the new part by drilling/welding etc or am I better off fixing my existing crossmember?Sent from my iPhone using Tapatalk Link to post Share on other sites
paceo 22 Posted November 8, 2013 Report Share Posted November 8, 2013 (edited) weird you havent got the 3x holes for the studs either!! ive got a mk3 vr6 crossmember you can have if you want with the correct hole, im located on the surrey / kent border so close to you! £10 if you want it! Edited November 8, 2013 by paceo Link to post Share on other sites
palmer 17 Posted November 8, 2013 Report Share Posted November 8, 2013 Looks like they forgot to drill it at the factory :-/ Sent from my GT-I9505 using Tapatalk Link to post Share on other sites
