MaidenVR6 26 Posted December 3, 2013 Report Share Posted December 3, 2013 10-11psi on stock CR is not a problem. Even the stock fuelpump is fine with it. Around 300whp.. Link to post Share on other sites
MaidenVR6 26 Posted December 3, 2013 Report Share Posted December 3, 2013 3" DP and exhaust is a must. Link to post Share on other sites
B-Man 16 Posted December 3, 2013 Author Report Share Posted December 3, 2013 3" DP and exhaust is a must.Yip,thats what I have! Sent from my iPhone using Tapatalk Link to post Share on other sites
coullstar 2 Posted December 3, 2013 Report Share Posted December 3, 2013 Is the split in the hose not to allow a t-piece in for the turbo cooliant line? Seem to remember on mine I have to t-into that hose when fitting a water cooled GT35. Link to post Share on other sites
B-Man 16 Posted December 3, 2013 Author Report Share Posted December 3, 2013 Is the split in the hose not to allow a t-piece in for the turbo cooliant line? Seem to remember on mine I have to t-into that hose when fitting a water cooled GT35.It T's off from the the coolant bottle (see pic),the bottom one where the split is should be the same. I just got a double ended hose connector,job done! Sent from my iPhone using Tapatalk Link to post Share on other sites
B-Man 16 Posted December 4, 2013 Author Report Share Posted December 4, 2013 And she has arrived! Sent from my iPhone using Tapatalk VR6Pete 1 Link to post Share on other sites
Russvrt 85 Posted December 5, 2013 Report Share Posted December 5, 2013 Nice,! Looks the same as mine .. Link to post Share on other sites
B-Man 16 Posted December 5, 2013 Author Report Share Posted December 5, 2013 Nice,! Looks the same as mine ..Thanks. Thats good cause I need to know where the pipes go! Lol! Sent from my iPhone using Tapatalk Link to post Share on other sites
Russvrt 85 Posted December 5, 2013 Report Share Posted December 5, 2013 Ha ha,no probs two bigger ones are for brake servo and isv,,small one is to fuel pressure reg vacume..Any more pics of what you've done so far ? Have you had to move the brake reservoir for the turbo inlet? Link to post Share on other sites
B-Man 16 Posted December 5, 2013 Author Report Share Posted December 5, 2013 Ha ha,no probs two bigger ones are for brake servo and isv,,small one is to fuel pressure reg vacume..Any more pics of what you've done so far ? Have you had to move the brake reservoir for the turbo inlet?Thanks. Im going to work on her some more tomorrow,will put some more pics on then.No the brake reservoir is still in place which is good,tight but all fits! Sent from my iPhone using Tapatalk VR6Pete 1 Link to post Share on other sites
B-Man 16 Posted December 7, 2013 Author Report Share Posted December 7, 2013 So...getting there now... Shortrunner on! Also got a little blanky for MR Garrett! Sent from my iPhone using Tapatalk Link to post Share on other sites
Swivelonit 119 Posted December 7, 2013 Report Share Posted December 7, 2013 what Garrett have you fitted? Link to post Share on other sites
B-Man 16 Posted December 7, 2013 Author Report Share Posted December 7, 2013 what Garrett have you fitted? GT3582rSent from my iPhone using Tapatalk Link to post Share on other sites
Daverse 175 Posted December 7, 2013 Report Share Posted December 7, 2013 Think your gonna have to clock the compressor housing round a bit! Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
Russvrt 85 Posted December 7, 2013 Report Share Posted December 7, 2013 Nice work,, how long before its ready to fire up? Link to post Share on other sites
B-Man 16 Posted December 7, 2013 Author Report Share Posted December 7, 2013 Nice work,, how long before its ready to fire up?Thanks! Just waiting for Sump,exhaust clamp and 1 hose then its fire up time...fingers crossed! I want to say by Wednesday latest so lets see.Sent from my iPhone using Tapatalk Link to post Share on other sites
B-Man 16 Posted December 7, 2013 Author Report Share Posted December 7, 2013 20vtvw....did u make use of this connector that use to plug in to the side of the original intake or disregard it now?Sent from my iPhone using Tapatalk Link to post Share on other sites
Russvrt 85 Posted December 7, 2013 Report Share Posted December 7, 2013 Yes that's the intake temp ,take the sensor out of your vr manifold and there is a threaded hole for it under the short runner..Hope that makes sense? J4Y VR 1 Link to post Share on other sites
B-Man 16 Posted December 8, 2013 Author Report Share Posted December 8, 2013 Yes that's the intake temp ,take the sensor out of your vr manifold and there is a threaded hole for it under the short runner..Hope that makes sense?Ya it does,was just wondering if its needed and if it would make a difference by plugging it in or not?...Sent from my iPhone using Tapatalk Link to post Share on other sites
Therusterman 59 Posted December 8, 2013 Report Share Posted December 8, 2013 Ya it does,was just wondering if its needed and if it would make a difference by plugging it in or not?...Sent from my iPhone using Tapatalk Without it plugged in the ECU defaults to an inlet temperature of 20 degrees I think. Mine had an issue recently and the car would stall on start up when warm. I'm guessing the OP will be using an aftermarket engine management ecu, and this probably takes a reading from this sensor too. I have read on some forums the sensor is better located near the air box (or air inlet) to get a truer indication of intake temperatures, as the temps in the inlet manifold may suffer from heat soak. Link to post Share on other sites
B-Man 16 Posted December 8, 2013 Author Report Share Posted December 8, 2013 Adapted the original heat shield to make it fit. Obviousely needs finishing and will be painted in black...Sent from my iPhone using Tapatalk Ickyketseddie 1 Link to post Share on other sites
daveyboy 897 Posted December 8, 2013 Report Share Posted December 8, 2013 I'm getting jealous reading your write up. Need to start collecting bits and bobs to start mission boost on mine Sent from my LT26i using Tapatalk B-Man 1 Link to post Share on other sites
Daverse 175 Posted December 9, 2013 Report Share Posted December 9, 2013 That T piece for the coolant line is a cool touch. Not long now what software are you running? Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
B-Man 16 Posted December 9, 2013 Author Report Share Posted December 9, 2013 That T piece for the coolant line is a cool touch. Not long now what software are you running?Sent from my GT-I9300 using TapatalkCheers Daverse,630cc injectors.4" maf Ecu remapped to 300-600bhp depending on what boost I run.So will have my Final bits tomorrow and Wednesday so fire up day will be Wednesday if all goes well! Sent from my iPhone using Tapatalk Link to post Share on other sites
B-Man 16 Posted December 10, 2013 Author Report Share Posted December 10, 2013 So i need to relocate the battery to the boot,thought id get away with keeping it up front but nope, Turbo pipes are taking up the space! Some say I need to use a distribution block up front, can anyone recommend one? Link to post Share on other sites
