vr6 crankshaft main bearing cap numbers?
Go to solution Solved by RsvRob,
hi there
im putting my crankshaft back in today and have reaised that the crankshaft main caps hav numbers on them ?
i took them off in order but on my one i have 2 number 7?
i know one in the middle is for the thrust bearings
Also do the pistons have to go back into the same bore as they come out if im chaning the piston rings?
  • Solution
The caps will be numbered in order I'd think. The 7's should be end caps!!!
Pistons would be better going back into the same cylinders but it's the rings that count.
Just don't tell me your going to run it in softly lol
Sent from Dagobah
