how much power will a 02m 4 motion box take and what upgrades can be done.
As above don't mind spending a bit of money upgrading if there's stuff u can do but dont wanna be spending 4k on a gear set ..
Plans are to fit a lsd uprated .
Heard about replacing rivets in selectors?
New bearings
Is there some type of box strenthener to keep the box together ..
Anything else ..
Thanks
Depends on the box code. Strangely R32 boxes are not as strong as from the 4 motion. DRP code is a stronger box.
But standard boxes will take loads of torque, as has been proved many times by the R32 turbos out there, if turboing the 4mo then it's probably worth investing in longer gears, it's a job on my list IF I keep my car. Basically a diesel 6 speed internals inside the 4 mo box
