Vince12v 20 Posted November 21, 2013 Report Share Posted November 21, 2013 Does anyone kno if the rear brake 256mm set up will fit on my mk3 golf ??Sent from my iPhone using Tapatalk Link to post Share on other sites
Marneus 78 Posted November 21, 2013 Report Share Posted November 21, 2013 I think the VR6 already has 256mm rear discs. Link to post Share on other sites
Vince12v 20 Posted November 21, 2013 Author Report Share Posted November 21, 2013 I thought they was 239mm??Sent from my iPhone using Tapatalk Link to post Share on other sites
Marneus 78 Posted November 21, 2013 Report Share Posted November 21, 2013 I could be wrong mate, I thought they were 288mm up front & 256mm at the back..... Haven't measured any mind Link to post Share on other sites
Lukey. 381 Posted November 21, 2013 Report Share Posted November 21, 2013 226 rears Link to post Share on other sites
Ickyketseddie 89 Posted November 21, 2013 Report Share Posted November 21, 2013 The rears do so little are you sure it's worth the hassle?Sent from my iPad using Tapatalk Link to post Share on other sites
craggsy 91 Posted November 21, 2013 Report Share Posted November 21, 2013 I wouldn't bother with the rears. Just make sure they work properly. New sliders, piston seals and hand brake mech is tip top then get some decent pads in there Link to post Share on other sites
Lukey. 381 Posted November 21, 2013 Report Share Posted November 21, 2013 If you disable the ABS you'll find out that the rear is almost over braked already with stock rears. Link to post Share on other sites
michael5556 247 Posted November 22, 2013 Report Share Posted November 22, 2013 226. You can upgrade to mk4/TT discs by using a polo stub and wheel bearing. Vented rear. I'm putting large brakes on the rear. Link to post Share on other sites
