If they are components the wiring gets a bit more tricky as you have to isolate which wire goes to what with the woofers and tweeters. A lot of speaker designs are too deep aswell which will foul on the window mechanism on the back side. This can be fixed if not too bad by spacing the speaker out a mil or so, also if you want to fit the stock plastic covers back over you will usually have to either trim or flatten some of the edge area on the woofers. If you're only using the stereo to drive them don't go too high powered on the speakers as they will be designed for an amp and the stereo will under drive them and they'll sound shite.
I'll second that
Sent from my LT26i using Tapatalk
I have rainbow three way speakers in mine but you need to modify dash vent on the nearside and the tweeters are not hidden. You have to have these amped up as the power is a higher. The standard speaker wire runs from the stereo to the tweeter in the dash then onto the door speaker so is fairly easy to add crossover at this point.
That's what I did, the crossovers are behind the far dash vents on each side numbers late tape to the dash bar. I gutted the standard tweeter holders and mounted the inphase ones in there, you have to mount them from under instead of on top but it works fine and looks stock.
Edited by Lukey.
