Hello,
I'll be replacing my headgasket over winter using a later metal headgasket.
I've done some research and everyone recommends using a copper spray to seal the gasket; specifically 'permatex' copper spray.
The issue is that a lot of the threads I'm finding are from a few years ago and the issue is I can't find a UK supplier of any copper gasket spray. It appears due to being an aerosol, no one will ship it anymore.
What do people recommend to use now?
A properly skimmed head and decked block. With New bolts and gasket will seal correctly if fitted correctly. No need for any kind of sealant.
Sent from Dagobah
In an ideal world yeah, but judging by the previous posts people have made; metal gaskets are know to leak from the one way oil valve near cylinder one and copper spray has solved it. For the sake of £10 it's not going to hurt. :)
