  • 3 months later...
if your wires are cut from your speakers try running a amp that is less than a 1000w preferbly 4 channel hook yourself up with a paremetric and run straight too your cd player via rca for mid range and for sub run a more powerful amp and run also through your paremetric that runs to your cd player
Parametric equalizers are effective when shaping the tone of an audio signal. The controls allow for the user to be precise in selecting a frequency to boost or cut, which is helpful if the signal is feeding back or has an unpleasant overtone. CALICO maybe u should learn how to use google my friend before u go about insulting people
then read the previous comment finish
What are you on about try reading your first post in this thread then you come back with a different spelling. None of what you said has anything to do with what the OP wanted try reading his first post. Then explain what are you on about in your last post its not even an English way of writing.
You don't need to in his second post he spelt it correctly but it is still irrelevant because the OP has not mentioned what wire he has cut so no need to tell him to get an expensive equaliser which wont fix the problem. If you have a slipping clutch you would not buy a new gearbox
Maybe so, but there is still no need to post insulting someone on something they have put regarding spelling or anything of that sort when you know nothing about the person, you wouldn't say it like that to the face of someone you just met, without knowing anything about them would you?
IMHO comments like the above are what makes a helpful forum end up like vw vortex or similar, where people come to bitch and take the piss. That's my opinion. Thanks
