rbertnitro 0 Posted December 13, 2013 Report Share Posted December 13, 2013 Hi im looking for some info on power steering pumps. I hit some debris and the damage its done is knocking the small right angled pipe connector for the rubber retun hose on the bottom of the pump. The 90deg pipe is now really wobbly in the pump and leaking fluid past. Question is. Is this part just on a thread and a screw in pipe fitting, if so it would seem the thread has just broken and is now loose.Can you get these parts seperate or use some other form of metal pipe fitting? as the rest of the pump itself looks good as are the pipes and rubber hoses. Thanks Link to post Share on other sites
