right guys havent had my car long and the car has been pulling to the left quite bad since had it.jacked it up the other day and noticed that the inside of the tyre on the passenger side is worn leading me to think that the tracking is out.plus when i accelerate it pulls really badly then when lef off the accelerator its not so bad
Edited by Vr6pates
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Have found a place and theyve done it now.thankyou for your help tho
Well after seeing that about engine mounts I recently renewed an engine mount on the passenger side and noticed that the gearbox wining after it
Basically every front wheel drive car with a open diff and a bit of power will get some torque steer as the gearbox isn't centrally mounted. It's not a fault as such just how fwd cars work. You can st
Posted Images
After having it tracked drove it home which is bout 2mins away from me but the roads are terrible but gping shopping today on the motorway its still the same pulling to the ledt.get annoyd with the car now cus just chucking gud money at it and nothing getting any better help help please
Ball joints what do you mean drive shaft etc
 No I mean ball joints.
 On the wheel end of the wishbone is ball joint, it fits to the bottom of the strut/hub assembly and these wear, become slack and can present the symptoms you described.
Here, it is item number ten near the bottom right of the image.
post-93090-0-54881400-1388432553_thumb.p
Edited by Swivelonit
