Vr6pates 2 Posted December 13, 2013 Report Share Posted December 13, 2013 (edited) right guys havent had my car long and the car has been pulling to the left quite bad since had it.jacked it up the other day and noticed that the inside of the tyre on the passenger side is worn leading me to think that the tracking is out.plus when i accelerate it pulls really badly then when lef off the accelerator its not so bad Edited December 13, 2013 by Vr6pates Link to post Share on other sites
andymk312v 15 Posted December 13, 2013 Report Share Posted December 13, 2013 Definitely tracking, I ruined a pair of 914's in under 1k. The car drives completely different now.But always check for play in all points of movement before getting it done, no point taking it all apart after having it aligned. Link to post Share on other sites
Vr6pates 2 Posted December 13, 2013 Author Report Share Posted December 13, 2013 ok will have a look as i had my mot today and he said there was no play in track rods and bottom arm bushes just that they were abit spong.but when putting wheel back on the other day and tightenening the nuts up i noticed the wheel would move back abit Link to post Share on other sites
CALICO 130 Posted December 13, 2013 Report Share Posted December 13, 2013 Wishbone bushes may have gone soft might be worth putting some R32 or aftermarket bushes in then having 4 wheel alignment Link to post Share on other sites
Vr6pates 2 Posted December 28, 2013 Author Report Share Posted December 28, 2013 Have fitted new tie rods and track rod ends today and now ive got a problem that nobody will track it for me cus its been lowered wat a load of bxxxxxxs.i wudnt mind but they can still get the clamps on so wats the problem Link to post Share on other sites
Surreyvr6 199 Posted December 28, 2013 Report Share Posted December 28, 2013 Ring around, I know a few places that will do lowered cars, where abouts are you? Sent from my iPhone using Tapatalk Link to post Share on other sites
Vr6pates 2 Posted December 28, 2013 Author Report Share Posted December 28, 2013 Have found a place and theyve done it now.thankyou for your help tho VR6Pete 1 Link to post Share on other sites
Vr6pates 2 Posted December 29, 2013 Author Report Share Posted December 29, 2013 After having it tracked drove it home which is bout 2mins away from me but the roads are terrible but gping shopping today on the motorway its still the same pulling to the ledt.get annoyd with the car now cus just chucking gud money at it and nothing getting any better help help please Link to post Share on other sites
Vr6pates 2 Posted December 29, 2013 Author Report Share Posted December 29, 2013 What else could cause this bottom arm bushes etc Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Have swapped my two front wheels over and still no joy.have spokon to jodie at midland vw and he says its the rack he guna put it on the geometry machine and have a luk but from the feeling its seems easier tobturn left than right Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 So my next question is where to get a rack from do i get a recon one or new Link to post Share on other sites
Swivelonit 119 Posted December 30, 2013 Report Share Posted December 30, 2013 (edited) Jack your car up and check the bottom ball joints, it is likely one is worn. I can't see it being a rack but if you do need one, these guys are really good, service exchange set up ACS Edited December 30, 2013 by Swivelonit Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Ball joints what do you mean drive shaft etc Link to post Share on other sites
Swivelonit 119 Posted December 30, 2013 Report Share Posted December 30, 2013 (edited) Ball joints what do you mean drive shaft etc No I mean ball joints. On the wheel end of the wishbone is ball joint, it fits to the bottom of the strut/hub assembly and these wear, become slack and can present the symptoms you described. Here, it is item number ten near the bottom right of the image. Edited December 30, 2013 by Swivelonit Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Oh briliant thankyou i hope its this maybe i could changevthe bottom arm bushes and the anti roll bar connections like number 17 in the picture Link to post Share on other sites
Swivelonit 119 Posted December 30, 2013 Report Share Posted December 30, 2013 chances are it will be number 10 or number 4, you can check arb bushes and brackets for play I suppose. Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Ok thanks i will try that 1st its cheaper and not a bigger job as doing the rack tbh.alot of people said to change them for r32 and tt bushes or something is this right Link to post Share on other sites
Swivelonit 119 Posted December 30, 2013 Report Share Posted December 30, 2013 TT bushes are solid rubber and are generally better, the standard bush has rubber with a few holes that you can see through so are a little softer, same diameter though so will be fine. good luck with it. Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Ok then i know there is two bushes on the bottom arms so do i change the back one for r32 and which one for the front Link to post Share on other sites
Swivelonit 119 Posted December 30, 2013 Report Share Posted December 30, 2013 Yes the back one, number 4 on the diagram Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Ok then so what should i use for number 6 to bolt through bush ie Link to post Share on other sites
Swivelonit 119 Posted December 30, 2013 Report Share Posted December 30, 2013 A new bolt and a new bush, a standard one for your Golf. Link to post Share on other sites
Vr6pates 2 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Ok then thankyou will order them now Link to post Share on other sites
andymk312v 15 Posted December 30, 2013 Report Share Posted December 30, 2013 Or have a look at flow flex polyurethane bushes good quality for cheaps.And steer clear of the cheapest balljoints they are crap quality. Link to post Share on other sites
Vr6pates 2 Posted December 31, 2013 Author Report Share Posted December 31, 2013 Well ive just bought some ball joints off ebay these are them there made in germany so 220785795000.wher to get bushes from i dont know Link to post Share on other sites
