abvsean 32 Posted December 17, 2013 Report Share Posted December 17, 2013 I didnt know what section to put this in but its just a general mechanical question/queery really I need to replace my inner cv boots as they got abit cooked when removing the bolts with a blow lamp. i just want to know how to remove the knuckle joint off the inner joint so i can put the boots on and leave the hub assembly alone (the engine is out you see,its using corrado widetrack running gear and corrado driveshafts) any help would be much appriciated cheers Link to post Share on other sites
GordonC 20 Posted December 18, 2013 Report Share Posted December 18, 2013 There is a circlip on the shaft that you need to take off then just chap it off with a hammer mate but make sure you remember what way the bearing cage goes and how the bearings fit in as its a knightmare to put back together VR6Pete 1 Link to post Share on other sites
abvsean 32 Posted December 18, 2013 Author Report Share Posted December 18, 2013 sounds like a wonderfull job! cheers ill bear that in mind Link to post Share on other sites
