printedflunky 9 Posted December 18, 2013 Report Share Posted December 18, 2013 (edited) My VR started running like an angry badger last week so I took it to a VW specialist and they called me a few hours later telling me that it was either a burnt valve or a piston ring had shat itself either way I was looking at having to shell out a lot of cash to repair a 182000mile vehicle, so I did wht any sane person would do;I ordered:a new block6 new standard pistonsa set of genuine piston ringsa set of genuine gudgeonsa genuine set of wrist pinsan R32 crankand a set of custom made conrods (5.8mm shorter than standard)also sent a spare head I had lying around to a cylinder head tuner in Hastings for:porting and polishing5 angle valve seatslarger diameter vales (inlet and exhaust up by 2mm and 1.6mm).Then obviously a complete gasket set, chains and tensioners set, head bolts and other shiny bits from techtonics tuning in the states. Totally sane and rational actions from a totally normal VR owner Edited December 18, 2013 by printedflunky Ickyketseddie, Marneus and damian8588 3 Link to post Share on other sites
Therusterman 59 Posted December 18, 2013 Report Share Posted December 18, 2013 Dare I ask how much that little lot set you back?! Link to post Share on other sites
michael5556 247 Posted December 18, 2013 Report Share Posted December 18, 2013 5 angle valve seats.... Drooooool Marneus 1 Link to post Share on other sites
ssaunders 199 Posted December 19, 2013 Report Share Posted December 19, 2013 Dare I ask how much that little lot set you back?!this bloke has some 12 and 24Vhttp://www.ebay.co.uk/itm/Brand-New-Genuine-VW-2-8-VR6-93-98-Bare-engine-Block-Pistons-/161177849548?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2586f2cecc Link to post Share on other sites
printedflunky 9 Posted December 19, 2013 Author Report Share Posted December 19, 2013 this bloke has some 12 and 24Vhttp://www.ebay.co.uk/itm/Brand-New-Genuine-VW-2-8-VR6-93-98-Bare-engine-Block-Pistons-/161177849548?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2586f2ceccthat's the fella I bought my block and pistons from Link to post Share on other sites
coullstar 2 Posted December 20, 2013 Report Share Posted December 20, 2013 Interesting, What extra displacement does the R32 crank give? Im assuming its longer stroke than standard. Link to post Share on other sites
printedflunky 9 Posted December 20, 2013 Author Report Share Posted December 20, 2013 Dare I ask how much that little lot set you back?!It's not as much as you might think to be honest, as I said in this^^^^^^^^ post I got the block, pistons, piston rings, gudgeons and wrist pins for the princely sum of £465the R32 crank was £150 from a local scrappythe custom rods are £140 eachthe TT bits were $685 roughly £425supatech valves were £150the head work is yet to be completed but he quoted me £15 per port (x12=£180) £12 per valve to enlarge to bigger diameter plus another £8 per valve for the 5 angle seats.total spent and commit to spend is somewhere close to £2500 Link to post Share on other sites
printedflunky 9 Posted December 20, 2013 Author Report Share Posted December 20, 2013 Interesting, What extra displacement does the R32 crank give? Im assuming its longer stroke than standard. The crank has a stroke that is 5.8mm longer than the 12v vr6 which is 95.9mmso it will give :pi(40.5mm^2) x 95.9mm= 494157.8714625mm^3 per cylinderx6= 2964.947228775ccso in general terms it'll make it a 'real' 3lt vr6 RsvRob 1 Link to post Share on other sites
nezzi21 27 Posted December 22, 2013 Report Share Posted December 22, 2013 Be interesting to see what this puts out when done? Possibly picking up a vr6 that needs a bottom end rebuild, this has me thinking!! Link to post Share on other sites
printedflunky 9 Posted December 22, 2013 Author Report Share Posted December 22, 2013 I'm hoping for a stable 200 ponies without changing the camshafts and exhaust. Once the engine has bedded in and covered a couple of thousand miles I'll replace the cams and exhaust, get it put on a rolling road and get it live mapped. I would hope for 220hp without over stressing the engine. The whole idea behind not boring out and putting oversized pistons in was partly down to cost but mostly down to the fact that I don't want to drop reliability or thrash-ability (not sure that's a real word).The cylinder head shop.com thinks he'll be able to increase the flow rates by 30% but I don't know how that will transfer to power increase. Link to post Share on other sites
printedflunky 9 Posted January 7, 2014 Author Report Share Posted January 7, 2014 Arrrghhhhh! Need assistance, just spoke to the engineering firm and during conversationhe asked what I was using the new 'rods for so I told him what the plan is, he instantly replied with a question that I know I should have asked myself when I started all this:"have you taken into account for the increased volume there will be an increase in compression ratio?" "shite" was my rather eloquent reply.Subsequently I've been trying to work out how high the compression ratio will be if I leave the order on the 'rods as is.If anyone here could assist with the piston to deck figures, dish volume of the stock pistons and the compression height I would be very grateful so I can adjust the order and start the build proper. Link to post Share on other sites
ssaunders 199 Posted January 9, 2014 Report Share Posted January 9, 2014 Hi, How about this deal from ebay.dehttp://www.ebay.de/itm/VR6-Turbo-Motor-KOMPLETT-EINBAUFERTIG-GT30-HF-Golf-1-2-3-Corrado-Passat-Jetta-/181209939158?pt=DE_Autoteile&hash=item2a30f43cd6 here is a rough translation, all for about £3300The basis is a good used VR6 engine on which the followingWere installed or replaced parts :RF GT30 turbocharger 0.82AR (replica in TOP Quality)Turbo exhaust manifoldDIY RS2 wastegate76mm downpipe wrapped with heat protection470ccm injectorsSoftware tuning " Turbodödel " to 1.8 barShort intake manifold with side exitNew thermostat housing with a pipeOil supply and oil return linesWater supply turbochargerTiming Chain Kit ( original VW)R36 big end bearings with new boltsExhaust manifold NEWAnsaugbrückendichtung NEWCylinder head bolts NEWOil pan gasket NEWCompaction reduction by 2 x metal head gasket + plateNew oil filter and new water / heat exchanger6 new spark plugs RS4The motor is according to customereither ausgetattet with distributors or static ignition !The engine is supplied without a plug wire ! Performance expectations : About 450 hp at 1.8 bar boost pressure. This performance is easily navigable for the motor with stock pistons and connecting rods .From about 500HP then H -Shaft connecting rods as well as modified stock pistons should be installed.From about 700hp then forged pistons are needed. Optional changes: There are generally all turbocharger possible such as: Garrett GT3076R , GT3582R , etc. ..and T3/T4 or Precision turbocharger , prices on request.Other connecting rods, pistons and all special requests are also feasible and available on request.Of course, installation is also possible - price on request .Delivery time is approximately 1 week. Link to post Share on other sites
