This is my vrt had it about 6 weeks so far the only thing I've is have a new exhaust fitted because it was way too loud.
Brief spec is: Woosner forged pistons
Shot peened rods
Pelequin diff
Gt35r turbo
450cc injectors
H&R coilovers
G60 brakes
Bbs replica wheels
It's running united motorsport software with an apexi avcr boost controller set at a max of 1.4 bar and 1.25 for daily driving.
After winter main plan is some new wheels to be able to fit bigger brakes
Here's a couple of my mk1 too it's just a bog standard 1.1 with 16" rs' and coilovers
post-93567-0-20106200-1387562119_thumb.j
post-93567-0-30151400-1387562135_thumb.j
post-93567-0-87165100-1387562147_thumb.j
post-93567-0-29604400-1387562386_thumb.j
post-93567-0-48793800-1387562429_thumb.j
I think the MK2 is a re-incarnation of a grey/silver MK2 that we built for a local guy.
It was then sold to a guy in essex, and to cut a long story short, was reshelled in essex into what I think the car pictured above.
If the car is to the same spec. that we built, then the car, specifically the engine is wanting for nothing. It had a hand crafted full 3" stainless exhaust from the turbo back. 1.06 turbine GT35R turbo etc.
The block was a 2.8 bored to 82mm with forged low compression pistons. The engine was built from the ground up with a re-polished crankshaft and brand new bearings. I believe the rods are a set chosen from a batch of stock rods and shot peened.
I dont remember which clutch was fitted, I believe by the time it wrecked a few gearboxes that diesel a diesel final drive and gearset was fitted.
440cc injectors and 95mm MAF housing with matching software. Like I said earlier, a full 3" TIG Welded exhaust from the turbo back, the turbo being a 1.06 AR turbine GT35R. I believe the engine has 100% ARP hardware.
Apexi AVCR fully wired in. with different boost settings per gear and 3 boost settings in total. The boost will have been capped to 1.4 bar for the safety of the engine.
I cant speak for the rest of the car that you have.
Out of interest - How much did you pay for this car?
  • 4 weeks later...
First slight issue with it, the clutch release bearing has failed. I thought there was a noise but i couldn't work out where it was coming from, guess I know now. Took the box off today going to put a new helix paddle clutch in it, there's not a lot left on the current on and also do a few other little jobs while it's all apart.
  • 5 months later...
Got a few from when I spent a day detailing it but nothing exciting
Mk2 Golf VR6 Turbo by SteG40, on Flickr
image by SteG40, on Flickr
Parts ordered so hopefully back on the road early next week. Also treated it new brakes gone for some ferodo ds2500 pads up front see what there like, service and a few other bits and pieces it needed.
