Airbag resistor
3 Ohms resistor from memory . Don't know what model u have but my vagcom can turn off belts and s/wheel if aftermarkey parts r fitted.
VCDS will also do this but once disabled the airbag light will illuminate, that is why I have installed 2 ohm resistors to the seat loom, the resistor I have for the steering wheel also gives a reading of 2.2 ohms.
